Is there a way to change the value for Max Check Attempts on the default import. I want it to be 5 but will default to 1 no matter what template I change. It is tedious to use the Bulk Change to do it on new servers.
I have changed the following templates.
xiwizard_generic_service
xiwizard_generic_host for the host
/usr/local/nagiosxi/html/includes/configwizards/passiveobject/templates/passiveobject.cfg
/usr/local/nagiosxi/html/includes/configwizards/passivecheck/templates/passiveobject.cfg
Thanks!
Unconfigured Object Max Check Default
Re: Unconfigured Object Max Check Default
Altering this default is not currently an option. We are adding this capability in a future major release.
ok excellent, thanks.
We'll go ahead and close this thread. Thanks.
