Backup and Restore
This support forum board is for questions relating to Nagios Fusion.
detronict
Backup and Restore
Post by detronict »
Hi everyone,
We have built a new Fusion server.
The old-one was 2012 version with Redhat Linux.
The new one is 2014 version with CentOS.
Everything works fine now, but we found a bug in the fusion restore script.
The backup script creates a tar.gz file containing the backup.
The older versions creaed a zip file.
The restore script still tries to unzip the backup file and is unsuccessfull, because the backup has tar.gz format.
As mentioned we have worked around it, and everything works, but this should be corrected in the next update.
Kind Regards,
Rik Lijkendijk
Detron ICT beheer
Re: Backup and Restore
You are correct. Our "restore_fusion.sh" script needs to be updated. I posted an internal bug report (TASK ID 4884). Thanks for bringing our attention to this!
