Fix not seen in 2.4
BanditBBS
Fix not seen in 2.4
Post by BanditBBS »
I just installed 2014r2.4 and for the fix for http://tracker.nagios.com/view.php?id=600 I still don't see it for the second time its marked as closed. check the attached image, names still not alphabetized and the box still small, makes it hard to use when you have 100+ users.
Am I missing something here or is it still not resolved?
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
Re: Fix not seen in 2.4
User components don't auto update when you upgrade XI. You can download this component from
http://library.nagios.com/library/produ ... -component
BanditBBS
Post by BanditBBS »
scottwilkerson wrote:User components don't auto update when you upgrade XI. You can download this component from
Thanks Scott!
Now to remember my library username...time to email sales.
I just have one question...where can I see User components so I know if there are any others I need to update, because according to the manage components screen I am up to date on everything.
Thanks!
EDIT - OMFG - I was on my wrong server when I check component upgrades....just ignore me...I need more Mt Dew! Lock this up!
cmerchant
Post by cmerchant »
From Admin, Manage Components, click on CHECK FOR UPDATES.
