2014R2.4 CCM Click area small
BanditBBS
Post by BanditBBS »
In the CCM in 2.3 and below you could click on the words in the menu to expand or close the particular section. In 2.4 it seems you now have to be much more precise and only able to click on the little arrow next to the section heading. Can that be reverted?
I use chrome, no clue if behavior exists in the other browsers but it definitely has changed.
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
krobertson71
Re: 2014R2.4 CCM Click area small
Post by krobertson71 »
Actually I am having that same issue in r2.3. I have to click on the arrow to open/close the section. Clicking on the work has never worked.
Sorry at first I was like "what is he talking about" then it hit me. I have tried in Firefox and Chrome in 2.3, have to click the arrow. Clicking on the word has never worked.
Now it could be that I am running a Unbuntu 14.04 OS versus Windows. That would be the only difference I could see.
BanditBBS
Post by BanditBBS »
Hmmm, my 2.0 server is the same, difference in the 2.0 is most of the menus are open by default, so I must just be imaging the larger click area, my bad. But with more of the menus collapsed by defualt now it will get on my nervs just a bit, especially since the cursor changes to a hand over the word too but just doesn't do anything.
I put in the feature request for this a week or so ago:
http://support.nagios.com/forum/viewtop ... 65#p123065
Bugs me just as much as anyone, and it was definitely possible in earlier versions.
BanditBBS
Post by BanditBBS »
tmcdonald wrote:I put in the feature request for this a week or so ago:
Thanks Trevor, lock this up!
