@timestamp offset
stecino
@timestamp offset
Post by stecino »
I have 3 hour offset, EST vs PST between @timestamp value and timestamp in the messages. How can I correct the time so it's in pacific time?
@timestamp message
2015-01-21T18:19:47.000-08:00 21 Jan 2015 21:19:45 DEBUG org.quartz.impl.jdbcjobstore.StdRowLockSemaphore - Lock 'TRIGGER_ACCESS' retuned by: DefaultQuartzScheduler_Worker-...
2015-01-21T18:19:47.000-08:00 21 Jan 2015 21:19:42 DEBUG org.quartz.impl.jdbcjobstore.StdRowLockSemaphore - Lock 'TRIGGER_ACCESS' is desired by: DefaultQuartzScheduler_Quar...
2015-01-21T18:19:47.000-08:00 21 Jan 2015 21:19:42 INFO org.quartz.plugins.history.LoggingTriggerHistoryPlugin - Trigger CORE_JOB_GROUP.coreJobRetrievalCronTrigger completed firing job
2015-01-21T18:19:47.000-08:00 21 Jan 2015 21:19:40 DEBUG org.quartz.impl.jdbcjobstore.StdRowLockSemaphore - Lock 'TRIGGER_ACCESS' is desired by: DefaultQuartzScheduler_Quar...
Re: @timestamp offset
What version of Logserver are you using? This was a bug in previous versions and either an update or a manual correction will fix it:
http://support.nagios.com/forum/viewtop ... 20#p119302
stecino
Post by stecino »
tmcdonald wrote:What version of Logserver are you using? This was a bug in previous versions and either an update or a manual correction will fix it:
It's 2015R1.1, I will take a look at the manual fix and let you know
stecino
Post by stecino »
Seems to be working. Thanks for the tip!!
You're quite welcome.
I'll be closing this thread now, but feel free to open another if you need anything in the future!
