Dear Expert
NAGVIS by default logged as User : Guest , whatever I did, clearing cookies/cache/temp files, restart PC but no success. Tried on Windows/Macintosh, different browser but no success.
NagVis 1.7 Documentation
How to fix?
Regards
Zajil NMS
Re: NAGVIS by default logged as User : Guest
The default (supported) version of NagVis that comes with Nagios XI is 1.5.9. Have you upgraded it to 1.7 or made any mods to NagVis? This is definitely not a default behavior...
Thanks lmiltchev for quick reply.
I will get back to you.
Regards
Regards
Zajil NMS
Great, let us know how the upgrade goes.
Dear Expert
Please close the case , issue sorted out
Its related to file : /etc/httpd/conf.d/nagvis.conf
When there was issue : # NagVis Apache2 split auth virtualhosts
Fixed after restored with old file : # NagVis Apache2 sample configuration file
Looks during some upgrade files got changed
New version 1.7 is good , stable.
Regards
Regards
Zajil NMS
We'll go ahead and close the thread. Thanks.
