Execute a script when a host/service problem is acknowledged
mon-team
Post by mon-team »
Hi Team,
We would like to execute a command on nagiosXI server when a host/service problem is acknowledged.
Do you have any idea/suggestion on how to implement this?
Thanks for your help.
Best Regards
Re: Execute a script when a host/service problem is acknowle
You will want to read up on Event Handlers:
http://assets.nagios.com/downloads/nagi ... ios-XI.pdf
mon-team
Post by mon-team »
Thank for your response but i don't think event handler is a solution because it is run only when host/services state change occurs.
I am looking for a solution to execute a script when a host/service problem is acknowledged/scheduled in downtime.
Thank in advance for your help
Best regards
The closest we have in XI is a Global Event Handler which can set scripts to run for every notification sent.
Admin -> Manage Components -> Global Event Handlers -> Edit -> Notifications Tab
