hello team,
Is there any way to add HostGroups utilizing something similar to bulk load function for Hosts (Bulk Host Cloning and Import)?
I do have at around 800+ locations (HostGroups) where each one will have X#s of windows Host machine to monitor.
Thank you
Add Multiple HostGroups all at once
Re: Add Multiple HostGroups all at once
Well, there is currently no way to load a hostgroup and then hand select what hosts you want to carry over like you can do with the Cloning wizard. You could however, clone a hostgroup in the CCM and then shift the hosts around. You could alternatively script a solution to build configuration files, then import them back into XI.
nagwindmon
got it, good idea, clone hostgroup and then shuffle hosts as needed, will try that, thanks!
Sounds good! Let us know if you get stuck on something.
