Graph Explorer - Select Host Issue
bspeed
Post by bspeed »
Since 2.0 I've been noticing a few issues with Graph Explorer. Now with 2.4 they all seem pretty much fixed except the "Select Host" drop down menu. The further I scroll down the list of hosts I notice that the host my mouse is hovering on is further and further away from the one that is highlighted and that gets selected.. if that makes sense..
I've tested in IE10 and Chrome (Chrome is a bit better because it does end up with the correct host when I select it, however the highlighting is off).
Anyone else noticing this? Thanks,
BanditBBS
Re: Graph Explorer - Select Host Issue
Post by BanditBBS »
Yeah, I definitely noticed this, just didn't care enough to post :) Would be nice to get it fixed though, clicking one thing and actually selecting another is a little bit of a pain.
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
I was able to recreate this behavior in IE (and partially in Chrome), so I filed an internal bug report (TASK ID 4903). Graph Explorer seemed to work fine in FF.
