error installing network analyzer
dino
Post by dino »
Any advise on this error? server running in centos7
/usr/bin/ld: rrdcached-rrd_daemon.o: undefined reference to symbol 'g_tree_replace'
/usr/bin/ld: note: 'g_tree_replace' is defined in DSO /lib64/libglib-2.0.so.0 so try adding it to the linker command line
/lib64/libglib-2.0.so.0: could not read symbols: Invalid operation
collect2: error: ld returned 1 exit status
make[2]: *** [rrdcached] Error 1
make[2]: Leaving directory `/tmp/nagiosna/rrdtool-1.4.8/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/tmp/nagiosna/rrdtool-1.4.8'
make: *** [all] Error 2
INSTALLATION ERROR!
in your communications with Nagios Enterprises technical support.
The step that failed was: 'rrdtool'
Re: error installing network analyzer
The current version of Network Analyzer can only be installed on CentOS or RHEL 5,6
http://assets.nagios.com/downloads/nagi ... quirements
Support for CentOS 7 will be coming in the next release.
