Nagios XI: Host Status DOWN
CentAdm_CPDC
Post by CentAdm_CPDC »
I am having the same problem with my with Nagios XI. After adding a hosts all of the host status when down with the services still up.
I am getting the same warning message :
There is warning message: This plugin must be either run as root or setuid root. But I have confirmed this that all the plugins under /usr/local/nagios/libexec all have their user set as ‘root’.
but when I tried to reconfigure I get an error messages : Error: Service has no hosts and/or service_description (config file '/usr/local/nagios/etc/services/192.168.66.24.cfg', starting on line 16)
Would anyone be able to help me
Re: Nagios XI: Host Status DOWN
Can you go to Config -> CCM -> Tools -> Write Config Files
Click Delete
Click Write
Click Verify
If all is OK, click restart.
Then from the CLI please run
./reconfigure_nagios.sh
CentAdm_CPDC
Hi
the output is on the txt file
What OS and version are you running?
What XI version are you running?
CentAdm_CPDC
All of this happen after the upgrade
CentOS 7
Nagios XI 2014R2.5
Can you run the following command and show us the output?
ll /usr/local/nagiosxi/scripts
CentAdm_CPDC
Hello
the scripts output is attached
There is a known bug with the current version on CentOS 7
Please extract the attached zip to /usr/local/nagiosxi/scripts and it should resolve the issue
scripts.zip
