Our server has been updated via "yum update". If NagiosXI is still working perfectly, all the bandwith services using check_rrdtraf from the Switch/Router Wizard stopped working. The rrd files are now populated with NAN.
When verifying the mrtg.cfg we got:
Our server is a CentOS 6, rrdtool version is 1.3.8-7.el6, and NagiosXI is 2014R2.5.[root@localhost var]# sudo-u apache LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg
2015-01-29 15:33:35: ERROR: Creating templock /etc/mrtg/mrtg.cfg_l_16199: Permission denied at /usr/bin/mrtg line 1829.
All files in /etc/mrtg/conf.d/ are owned by apache:nagios in 775.
The mrtg.cfg is :
What can we do fix this permission problem ? We tried the script NagiosXI-FixPerms.sh but it didn't help.HtmlDir: /var/www/mrtg
ImageDir: /var/www/mrtg
LogFormat: rrdtool
LogDir: /var/lib/mrtg
ThreshDir: /var/lib/mrtg
WorkDir: /var/lib/mrtg
Include: conf.d/*.cfg
Forks: 4
