Monitoring free disk space in Windows
fao
Post by fao »
We'd like to set an alert in order to be notified when free disk space on a Windows drive reaches 300 MB.
Is there a way to modify the check_nt command to accomplish this or another plug-in?
agriffin
Re: Monitoring free disk space in Windows
Post by agriffin »
You can accomplish this using check_nrpe instead of check_nt by following the docs here and here (in particular, the example commands are very helpful).
Let me know if you run into any trouble following that documentation.
pnewlon
Post by pnewlon »
we are using windows snmp with informant-std to query processor, disk, memory
http://www.wtcs.org/informant/download.htm
check_snmp -H $HOSTADDRESS$ $ARG1$ -o .1.3.6.1.4.1.9600.1.1.1.1.20.6.95.84.111.116.97.108 -C private -P 1 -l "DiskFreeSpace" -u "Megabytes" -m INFORMANT-STD -w 10000: -c 5000:
nscott
Post by nscott »
pnewlon,
It looks like you've a large Windows environment. Do you use WMI at all for it?
Nicholas Scott
pnewlon
Post by pnewlon »
For PCI security reasons, we are not permitted to use WMI so we are using SNMP. From a traffic over the WAN perspective, SNMP is much more gentle on the pipes too. The Informant MIB is an extension of the standard Windows MIB. The installer is (can be) quiet and very small.
nscott
Post by nscott »
pnewlon,
Thanks for the input, any time I can get real world reasons, it makes me happy.
Nicholas Scott
pnewlon
Post by pnewlon »
My pleasure! I like to be able to help at least a little!
