gearmand failed to load module
I updated our test redhat6 server and noticed that gearmand was update
gearmand.x86_64 1:0.33-2 @labs_consol_stable
mod_gearman.x86_64 1.5.1-1.el6 @labs_consol_stable
logs show:
Jan 29 17:14:59 nagiosxi-tst nagios: Error: Could not load module '/usr/lib64/mod_gearman/mod_gearman.o' -> /usr/lib64/mod_gearman/mod_gearman.o: undefined symbol: check_result_list
Jan 29 17:14:59 nagiosxi-tst nagios: Error: Failed to load module '/usr/lib64/mod_gearman/mod_gearman.o'.
Jan 29 17:14:59 nagiosxi-tst nagios: ndomod: NDOMOD 2.0.0 (02-28-2014) Copyright (c) 2009 Nagios Core Development Team and Community Contributors
Jan 29 17:14:59 nagiosxi-tst nagios: ndomod: Could not open data sink! I'll keep trying, but some output may get lost...
Jan 29 17:14:59 nagiosxi-tst nagios: Event broker module '/usr/local/nagios/bin/ndomod.o' initialized successfully.
Jan 29 17:14:59 nagiosxi-tst nagios: Error: Module loading failed. Aborting.
So Nagios Core is not starting and of course gearmand services are not working. I am unable to submit commands from the XI interface and attempting to get into core results in an error.
So where do I start...? Compatibility issue with this version of gearmand? Where should I get the latest compatible version?
logs show:
- Box293
- Too Basu
Re: gearmand failed to load module
Mod Gearman will need updating.
Follow this guide:
http://assets.nagios.com/downloads/nagi ... ios_XI.pdf
Follow this guide:
Nagios Core still wouldn't work. I rebooted the server to ensure that everything came up ok.
I then found out that I was receiving error
tail -f /var/log/gearmand.log
ERROR 2015-01-30 00:55:21.000000 [ main ] socket()(Address family not supported by protocol) -> libgearman-server/gearmand.cc:468
ERROR 2015-01-30 00:55:21.000000 [ main ] gearmand_sockfd_close() called with an invalid socket -> libgearman-server/io.cc:933
ERROR 2015-01-30 00:55:25.000000 [ main ] socket()(Address family not supported by protocol) -> libgearman-server/gearmand.cc:468
ERROR 2015-01-30 00:55:25.000000 [ main ] gearmand_sockfd_close() called with an invalid socket -> libgearman-server/io.cc:933
ERROR 2015-01-30 00:57:55.000000 [ main ] socket()(Address family not supported by protocol) -> libgearman-server/gearmand.cc:468
ERROR 2015-01-30 00:57:55.000000 [ main ] gearmand_sockfd_close() called with an invalid socket -> libgearman-server/io.cc:933
ERROR 2015-01-30 01:04:42.000000 [ main ] socket()(Address family not supported by protocol) -> libgearman-server/gearmand.cc:468
ERROR 2015-01-30 01:04:42.000000 [ main ] gearmand_sockfd_close() called with an invalid socket -> libgearman-server/io.cc:933
ERROR 2015-01-30 01:05:28.000000 [ main ] socket()(Address family not supported by protocol) -> libgearman-server/gearmand.cc:468
ERROR 2015-01-30 01:05:28.000000 [ main ] gearmand_sockfd_close() called with an invalid socket -> libgearman-server/io.cc:933
I modified:
/etc/sysconfig/gearmand
OPTIONS="-L myipaddress"
Gearman still wouldn't start. I logged into nagios xi via the web and noticed that the monitoring engine process wasn't started. I started that back up through the web gui and then went back into the commandline and restarted gearmand. Gearmand worked and my worker shows they are connecting.
gearman_top -H myipaddress:4730
Queue Name | Worker Available | Jobs Waiting | Jobs Running
eventhandler | 21 | 0 | 0
host | 21 | 0 | 0
service | 21 | 0 | 0
worker_nagiosxi-tst | 1 | 0 | 0
worker_gearmanworker-tst | 1 | 0 | 0
Great so far.
I then attempt to schedule a forced an immediate check on a service over the web and I receive a
Please Wait
Your request was not processed in a timely manner. It may still execute, as the server may be temporarily busy.
I'm monitoring 3 test hosts so I know something else is wrong. Any ideas? The system status shows everything as good but the last checks that occurred were earlier in the day and no new active checks are happening.
I modified:
host | 21 | 0 | 0
Great so far.
Please Wait
- Box293
- Too Basu
Can you please post your nagios.cfg file and your /etc/mod_gearman/mod_gearman_neb.conf file.
Also, do you have workers on other machines, or do you just use a local worker?
nagios.cfg
# MODIFIED
admin_email=root@localhost
admin_pager=root@localhost
translate_passive_host_checks=1
log_event_handlers=0
use_large_installation_tweaks=1
enable_environment_macros=0
# NDOUtils module
broker_module=/usr/local/nagios/bin/ndomod.o config_file=/usr/local/nagios/etc/ndomod.cfg
#Gearman
broker_module=/usr/lib64/mod_gearman/mod_gearman.o config=/etc/mod_gearman/mod_gearman_neb.conf eventhandler=no
# PNP settings - bulk mode with NCPD
process_performance_data=1
# service performance data
service_perfdata_file=/usr/local/nagios/var/service-perfdata
service_perfdata_file_template=DATATYPE::SERVICEPERFDATA\tTIMET::$TIMET$\tHOSTNAME::$HOSTNAME$\tSERVICEDESC::$SERVICEDESC$\tSERVICEPERFDATA::$SERVICEPERFDATA$\tSERVICECHECKCOMMAND::$SERVICECHECKCOMMAND$\tHOSTSTATE::$HOSTSTATE$\tHOSTSTATETYPE::$HOSTSTATETYPE$\tSERVICESTATE::$SERVICESTATE$\tSERVICESTATETYPE::$SERVICESTATETYPE$\tSERVICEOUTPUT::$SERVICEOUTPUT$
service_perfdata_file_mode=a
service_perfdata_file_processing_interval=15
service_perfdata_file_processing_command=process-service-perfdata-file-bulk
# host performance data
host_perfdata_file=/usr/local/nagios/var/host-perfdata
host_perfdata_file_template=DATATYPE::HOSTPERFDATA\tTIMET::$TIMET$\tHOSTNAME::$HOSTNAME$\tHOSTPERFDATA::$HOSTPERFDATA$\tHOSTCHECKCOMMAND::$HOSTCHECKCOMMAND$\tHOSTSTATE::$HOSTSTATE$\tHOSTSTATETYPE::$HOSTSTATETYPE$\tHOSTOUTPUT::$HOSTOUTPUT$
host_perfdata_file_mode=a
host_perfdata_file_processing_interval=15
host_perfdata_file_processing_command=process-host-perfdata-file-bulk
# OBJECTS - UNMODIFIED
#cfg_file=/usr/local/nagios/etc/objects/commands.cfg
#cfg_file=/usr/local/nagios/etc/objects/contacts.cfg
#cfg_file=/usr/local/nagios/etc/objects/localhost.cfg
#cfg_file=/usr/local/nagios/etc/objects/templates.cfg
#cfg_file=/usr/local/nagios/etc/objects/timeperiods.cfg
# STATIC OBJECT DEFINITIONS (THESE DON'T GET EXPORTED/IMPORTED BY NAGIOSQL)
cfg_dir=/usr/local/nagios/etc/static
# OBJECTS EXPORTED FROM NAGIOSQL
cfg_file=/usr/local/nagios/etc/contacttemplates.cfg
cfg_file=/usr/local/nagios/etc/contactgroups.cfg
cfg_file=/usr/local/nagios/etc/contacts.cfg
cfg_file=/usr/local/nagios/etc/timeperiods.cfg
cfg_file=/usr/local/nagios/etc/commands.cfg
cfg_file=/usr/local/nagios/etc/hostgroups.cfg
cfg_file=/usr/local/nagios/etc/servicegroups.cfg
cfg_file=/usr/local/nagios/etc/hosttemplates.cfg
cfg_file=/usr/local/nagios/etc/servicetemplates.cfg
cfg_file=/usr/local/nagios/etc/servicedependencies.cfg
cfg_file=/usr/local/nagios/etc/serviceescalations.cfg
cfg_file=/usr/local/nagios/etc/hostdependencies.cfg
cfg_file=/usr/local/nagios/etc/hostescalations.cfg
cfg_file=/usr/local/nagios/etc/hostextinfo.cfg
cfg_file=/usr/local/nagios/etc/serviceextinfo.cfg
cfg_dir=/usr/local/nagios/etc/hosts
cfg_dir=/usr/local/nagios/etc/services
# GLOBAL EVENT HANDLERS
global_host_event_handler=xi_host_event_handler
global_service_event_handler=xi_service_event_handler
# UNMODIFIED
accept_passive_host_checks=1
additional_freshness_latency=15
auto_reschedule_checks=1
auto_rescheduling_interval=30
auto_rescheduling_window=45
bare_update_check=0
cached_host_check_horizon=15
cached_service_check_horizon=15
check_external_commands=1
check_for_orphaned_hosts=1
check_for_orphaned_services=1
check_for_updates=1
check_host_freshness=0
check_result_path=/usr/local/nagios/var/spool/checkresults
check_service_freshness=1
command_file=/usr/local/nagios/var/rw/nagios.cmd
daemon_dumps_core=0
date_format=us
debug_file=/usr/local/nagios/var/nagios.debug
debug_level=0
debug_verbosity=1
enable_event_handlers=1
enable_flap_detection=1
enable_notifications=1
event_broker_options=-1
event_handler_timeout=30
execute_host_checks=1
execute_service_checks=1
high_host_flap_threshold=20.0
host_check_timeout=30
interval_length=60
lock_file=/usr/local/nagios/var/nagios.lock
log_external_commands=0
log_file=/usr/local/nagios/var/nagios.log
log_host_retries=1
log_initial_states=0
log_notifications=1
log_passive_checks=0
log_rotation_method=d
log_service_retries=1
low_host_flap_threshold=5.0
max_check_result_reaper_time=30
max_concurrent_checks=0
max_debug_file_size=1000000
max_host_check_spread=30
max_service_check_spread=30
nagios_group=nagios
nagios_user=nagios
notification_timeout=30
object_cache_file=/usr/local/nagios/var/objects.cache
obsess_over_hosts=0
obsess_over_services=0
ocsp_timeout=5
perfdata_timeout=5
precached_object_file=/usr/local/nagios/var/objects.precache
resource_file=/usr/local/nagios/etc/resource.cfg
retain_state_information=1
retention_update_interval=60
service_check_timeout=60
service_interleave_factor=s
soft_state_dependencies=0
state_retention_file=/usr/local/nagios/var/retention.dat
status_file=/usr/local/nagios/var/status.dat
status_update_interval=10
temp_file=/usr/local/nagios/var/nagios.tmp
temp_path=/tmp
use_regexp_matching=0
use_retained_program_state=1
use_syslog=1
use_true_regexp_matching=0Re: gearmand failed to load module
debug=0
logfile=/var/log/mod_gearman/mod_gearman_neb.log
server=localhost:serverip:4730
eventhandler=yes
services=yes
hosts=yes
do_hostchecks=yes
route_eventhandler_like_checks=no
encryption=yes
key=this is set
use_uniq_jobs=on
localhostgroups=
localservicegroups=
result_workers=1
perfdata=no
perfdata_mode=1
orphan_host_checks=yes
orphan_service_checks=yes
accept_clear_results=no
debug=0
eventhandler=yes
services=yes
hosts=yes
do_hostchecks=yes
encryption=yes
key=this is set
use_uniq_jobs=on
localhostgroups=
localservicegroups=
result_workers=1
perfdata=no
perfdata_mode=1
I have the local worker and one other server also serving as a worker. The password is the same on all 3 configuration files.
- Box293
- Too Basu
Thanks for those files.
Did you update the remote worker as well?
In mod_gearman_neb.conf AND the local mod_gearman_worker.conf, can you please change:
This:
To:
Then
Does this help?
On your XI host, can you run this command and post the output"
This:
To:
server=127.0.0.1:4730Code: Select all
service nagios stop
service mod_gearman_worker stop
service gearmand restart
service mod_gearman_worker start
service nagios startOn your XI host, can you run this command and post the output"
iptables --listAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
I've disabled iptables for this test as well as selinux.
After I made changes to the IP address to be localhost the gearman worker on the localhost no longer seems to be checking in... this is shown when I run gearman_top
I do see this in the logs:.
mod_gearman_neb.log
[2015-01-30 09:11:34][30971][ERROR] sending job to gearmand failed: flush(GEARMAN_COULD_NOT_CONNECT) localhost:127 -> libgearman/connection.cc:745
mod_gearman_worker.log
[2015-01-30 09:13:39][31587][INFO ] mod_gearman worker daemon started with pid 31587
[2015-01-30 09:13:40][31587][INFO ] no checks in 2minutes, restarting all workers
[2015-01-30 09:15:41][31587][INFO ] no checks in 2minutes, restarting all workers
[2015-01-30 09:17:42][31587][INFO ] no checks in 2minutes, restarting all workers
[2015-01-30 09:19:43][31587][INFO ] no checks in 2minutes, restarting all workers
[2015-01-30 09:21:44][31587][INFO ] no checks in 2minutes, restarting all workers
[2015-01-30 09:23:45][31587][INFO ] no checks in 2minutes, restarting all workers
[2015-01-30 09:25:46][31587][INFO ] no checks in 2minutes, restarting all workers
mod_gearman_neb.log
Could you check the status of the Gearman worker?
Run this.
If it isn't running, could you start it?
Also could you post your worker config file and the log file?
Run this.
service mod_gearman_worker statusCode: Select all
service mod_gearman_worker startCode: Select all
/etc/mod_gearman/mod_gearman_worker.conf
/var/log/mod_gearman/mod_gearman_worker.log
