How to
WillemDH
How to
Post by WillemDH »
it seems not possible to edit the last 24 hour filter. I would like to be able to change this somehow when needed to last week, last month etc. How should I do this? I know I can zoom out in the map, but the graph will zoom outin the middle, resulting in half the graph being the future and empty.
How can I edit the last 24 hours filter in a dashboard?
Grtz
Nagios XI 5.8.1
https://outsideit.net
Re: How to
On the top of the screen, there is a pull down box to select different filter times. Is that what you are looking for?
WillemDH
Re: How to
Post by WillemDH »
That was exactly what I needed.
Thanks :) Thread can be closed.
Nagios XI 5.8.1
