New Update Available
I have updated my Nagios XI from 2.4 to 2.5 but it still tells me there is an update available. The release in the bottom left hand corner says 2.5 so curious what file is being looked at or what do I need to do in order to correct this?
Re: New Update Available
I posted this in http://support.nagios.com/forum/viewtop ... 16&t=31117
Here's the info:
"I just did an upgrade from 2014R1.5 to 2014R2.4 (picture 1) from within the web console, and after the upgrade and closing out of my web browser and clearing the cache and logging back into our Nagios XI web console, I noticed the discrepancy in picture 2."
UPDATE: "I clicked on "Check For Updates Now" and it appears to have refreshed/resolved itself."
See if that works.
Here's the info:
See if that works.
Newbie '14
There is a delay from when the update is done and the version message us updated.
Is the version updated for you yet?
Ok, after I clicked check for updates it cleared itself up.
You can close this post. Thanks!
