/var/log/nagios3/archives/nagios-01-20-2015-00.log
1421751380] Auto-save of retention data completed successfully.
[1421754980] Auto-save of retention data completed successfully.
[1421757490] SERVICE ALERT: Testserver2;Elastic_Search;WARNING;HARD;1;One or more indexes are missing replica shards. Use -vv to list them.
[1421757560] SERVICE ALERT: Testserver3;Elastic_Search;WARNING;HARD;1;One or more indexes are missing replica shards. Use -vv to list them.
[1421757670] SERVICE ALERT: Testserver1;Elastic_Search;WARNING;HARD;1;One or more indexes are missing replica shards. Use -vv to list them.
[1421757790] SERVICE ALERT: Testserver2;Elastic_Search;OK;HARD;1;Monitoring cluster 'production33'
[1421757860] SERVICE ALERT: Testserver3;Elastic_Search;OK;HARD;1;Monitoring cluster 'production33'
[1421758090] SERVICE ALERT: Testserver2;Elastic_Search;CRITICAL;HARD;1;[Errno 111] Connection refused
[1421758270] SERVICE ALERT: Testserver1;Elastic_Search;OK;HARD;1;Monitoring cluster 'production33'
[1421758390] SERVICE ALERT: Testserver2;Elastic_Search;OK;HARD;1;Monitoring cluster 'production33'
[1421758390] SERVICE FLAPPING ALERT: Testserver2;Elastic_Search;STARTED; Service appears to have started flapping (24.2% change >= 20.0% threshold)
[1421758580] Auto-save of retention data completed successfully.
[1421762180] Auto-save of retention data completed successfully.
[1421764090] SERVICE FLAPPING ALERT: Testserver2;Elastic_Search;STOPPED; Service appears to have stopped flapping (3.8% change < 5.0% threshold)
[1421765780] Auto-save of retention data completed successfully.Does that means the server detected the service status as flapping and didn't send the notifications ? In that case,how can I get atleast one notification such as the 'flapping is started and may stop further alerts for this service'.
Following are my configurations :
/etc/nagios3/servers/Testserver1.cfg
use generic-service_dd ; Name of service template to use
host_name Testserver1
service_description Elastic_Search
check_command check_nrpe_1arg!check_elasticsearch
vi /etc/nagios3/conf.d/g_generic.cfg
name generic-host_dd ; The name of this host template
notifications_enabled 1 ; Host notifications are enabled
event_handler_enabled 1 ; Host event handler is enabled
flap_detection_enabled 1 ; Flap detection is enabled
failure_prediction_enabled 1 ; Failure prediction is enabled
process_perf_data 1 ; Process performance data
retain_status_information 1 ; Retain status information across program restarts
retain_nonstatus_information 1 ; Retain non-status information across program restarts
max_check_attempts 10
notification_interval 0
notification_period 24x7
notification_options d,u,r
contact_groups gmail_group
register 0 ; DONT REGISTER THIS DEFINITION - ITS NOT A REAL HOST, JUST A TEMPLATE!
vi /etc/nagios3/conf.d/g_generic_service.cfg
# generic service template definition
name generic-service_dd ; The 'name' of this service template
active_checks_enabled 1 ; Active service checks are enabled
passive_checks_enabled 1 ; Passive service checks are enabled/accepted
parallelize_check 1 ; Active service checks should be parallelized (disabling this can lead to major performance problems)
obsess_over_service 1 ; We should obsess over this service (if necessary)
check_freshness 0 ; Default is to NOT check service 'freshness'
notifications_enabled 1 ; Service notifications are enabled
event_handler_enabled 1 ; Service event handler is enabled
notification_interval 0 ; Only send notifications on status change by default.
is_volatile 0
check_period 24x7
normal_check_interval 5
retry_check_interval 1
max_check_attempts 4
notification_options w,u,c,r
register 0 ; DONT REGISTER THIS DEFINITION - ITS NOT A REAL SERVICE, JUST A TEMPLATE!
vi /etc/nagios3/conf.d/g_contacts.cfg
define contact{
contact_name nagiosuser1
alias Root
service_notification_period 24x7
host_notification_period 24x7
service_notification_options w,u,c,r
host_notification_options d,r
service_notification_commands notify-service-by-email
host_notification_commands notify-host-by-email
email [email protected]
define contact{
contact_name nagiosuser2
alias Root
define contact{
contact_name Tom
alias Root
define contactgroup{
contactgroup_name gmail_group
alias client special contact Group
members nagiosuser1,nagiosuser2,Tom
