Importing query data
This is an example query result that I have exported to json, json2.txt contins the query body
curl -XGET 'http://xx.xx.1.246/nagioslogserver/inde ... 0b1d990a1a' -d json2.txt > test.json
I want to be able to convert this json into csv format. But when I put it through converter it complains about validity of json file. I used json validator and it complains on every message
"_index":"logstash-2015.01.30",
"_type":"syslog",
"_id":"5dfs8ONnTbWYr9w8-gfhqg",
"_score":1,
"_source":{
"message":"connect from unknown[
10.xx.xx.xxx
Assuming that json file generated is the same everytime, how can I get rid of this issue?
"_type":"syslog",
"_score":1,
"_source":{
10.xx.xx.xxx
Re: Importing query data
Unless this was just a typo on the forums, it looks like you left out the closing "}" bracket.
It was just a snippet, I fount out the root cause. It's because messages field is multiline instead of a single line. How can i go from multiline to single line?tmcdonald wrote:Unless this was just a typo on the forums, it looks like you left out the closing "}" bracket.
If you have logs with multiline input you would need to create a new input fo rthem adding the multiline codec
http://logstash.net/docs/1.4.2/codecs/multiline
this will definately require some knowledge of how the messages are written as you will have to form a pattern to match for the stream
Inspect generating the elasticsearch query, doesn't return all the results. It keeps returning 10 results
curl -XGET 'http://xx.xx.x.246/nagioslogserver/inde ... 0b1d990a1a'
Is there a way to bypass nagios, and hit ElasticSearch API directly?
curl -XGET 'http://127.0.0.1:9200/?pretty'Code: Select all
curl -XGET 'http://127.0.0.1:9200/_search?pretty&q=something'Former Nagios employee
For a specific issue in hand, I want to grab from index logstash-2015.02.05, all records that have a type=LTM302_logtmcdonald wrote:That will do a basic query that returns some info about the cluster. You can add the "_search" endpoint to the URL with a "&q=something" added on to search for "something":Code: Select all
Note that by default this needs to be done from the command line.Code: Select all
Would a query be something like this?
I am getting 0 hits
curl -XGET 'http://127.0.0.1:9200/_search?pretty&q= ... 2015.02.05'
"took" : 2982,
"timed_out" : false,
"_shards" : {
"total" : 161,
"successful" : 161,
"failed" : 0
"hits" : {
"total" : 0,
"max_score" : null,
"hits" : [ ]
I also tried type=syslog from current index, still getting 0 hits
[root@pbur2nls2 ~]# curl -XGET 'http://127.0.0.1:9200/_search?pretty&q= ... ype;syslog'
"took" : 1805,
"_shards" : {
"total" : 161,
"successful" : 161,
"failed" : 0
"hits" : {
"total" : 0,
"max_score" : null,
"hits" : [ ]
The semicolons in your query shouldn't be there, and you have one too many "q"s. Try this:
curl -XGET 'http://127.0.0.1:9200/logstash-2015.02.05/_search?q=type:LTM302_log&pretty'
what if I wanted to do multiple fileds, and also multiple index files, how can I do it, please?tmcdonald wrote:The semicolons in your query shouldn't be there, and you have one too many "q"s. Try this:
Can you give me an example?
Another thing I tried, please note this is a output snippet.
curl -XGET 'http://127.0.0.1:9200/logstash-2015.02. ... log&pretty'
"took" : 38,
"_shards" : {
"total" : 5,
"successful" : 5,
"failed" : 0
"hits" : {
"total" : 2504,
"max_score" : 1.0,
"hits" : [ {
"_index" : "logstash-2015.02.06",
"_type" : "eb_map_log",
"_id" : "SfbgpwBkRry3p8dHEVtckg",
"_score" : 1.0,
"_source":{"message":"06 Feb 2015 02:49:00 DEBUG com.platform.feed.twitter.service.impl.TwitterFollowerDispenserImpl - Twitter follower lists 2643230248140801 claimed, will run on server 204","@version":"1","@timestamp":"2015-02-06T10:49:07.000Z","type":"eb_map_log","host":"10.xx.xx.xxx","priority":133,"timestamp":"Feb 6 02:49:07","logsource":"xxxapi02","program":"eb_map_log","severity":5,"facility":16,"facility_label":"local0","severity_label":"Notice","geoip":{"ip":"xx.xx.xx.xx","country_code2":"US","country_code3":"USA","country_name":"United States","continent_code":"NA","region_name":"CA","city_name":"Burbank","postal_code":"91501","latitude":34.1994,"longitude":-118.29140000000001,"dma_code":803,"area_code":818,"timezone":"America/Los_Angeles","real_region_name":"California","location":[-118.29140000000001,34.1994]},"tags":["geoip"]}
instead of 2504 hits as indicated, it only returns 20 results in the hits list. Why is this the case?
"took" : 38,
"_shards" : {
"total" : 5,
"successful" : 5,
"failed" : 0
"hits" : {
"total" : 2504,
"max_score" : 1.0,
"hits" : [ {
"_score" : 1.0,
