Snippet from the PDF:
The BSM Connector for Nagios utilizes a proprietary NEB module k for the following functions:
l At startup, the NEB module registers a callback function for various events relevant to BSM.
After registering the callback function, the NEB pushes information to the NEB module at regular
intervals.
l The NEB module processes the information passed by the NEB callback function and passes it
on to an integration daemon.
The daemon passes the information to two streams, referred to as pipelines, each of which is
processed in a different manner, as follows:
l Events
One of the pipelines l holds event information. The integration daemon converts the information
to XML in a format compatible with BSM Connector m. A BSM Connector policy reads the XML
file and passes the Nagios events on to BSM.
l Metrics
The other pipeline n holds information used as metrics. The integration daemon converts the
information to a structured log file o. A BSM Connector policy reads the log file and passes the
metrics obtained from Nagios on to BSM.Code: Select all
<message>
<genint_meta>
<integration_name>HPBsmIntNagios</integration_name>
<integration_type>EVENT</integration_type>
</genint_meta>
<msg_node_name><![CDATA[esu1l268.federated.fds]]></msg_node_name>
<state><![CDATA[0]]></state>
<output><![CDATA[OK - 11.120.112.168: rta 45.119ms, lost 0%]]></output>
<current_state><![CDATA[0]]></current_state>
<current_state_name><![CDATA[OK]]></current_state_name>
<last_state><![CDATA[2]]></last_state>
<last_state_name><![CDATA[CRITICAL]]></last_state_name>
<current_event_id><![CDATA[130940]]></current_event_id>
<last_event_id><![CDATA[130602]]></last_event_id>
<service>
<description><![CDATA[Ping]]></description>
<display_name><![CDATA[Ping]]></display_name>
</service>
<host>
<name><![CDATA[s76d0z11]]></name>
<display_name><![CDATA[s76d0z11]]></display_name>
<alias><![CDATA[Solaris 10]]></alias>
<address><![CDATA[11.120.112.168]]></address>
</host>
<datetime>
<timestamp><![CDATA[1422645801]]></timestamp>
<iso><![CDATA[2015-01-30 14:23:21]]></iso>
</datetime>
</message>
