I have to install nrpe agent into solaris 10 to evaluate nagios xi but after install the nrpe agent, it was unable to start up. Below is the log attached.
Any idea to solve it?
root@cmnncs01> uname -a
SunOS cmnncs01 5.10 Generic_137111-07 sun4v sparc SUNW,SPARC-Enterprise-T5120
root@cmnncs01> cat /var/svc/log/application-nagios-nrpe:default.log
[ Feb 3 11:38:38 Disabled. ]
[ Feb 3 11:38:39 Rereading configuration. ]
[ Feb 3 11:39:10 Enabled. ]
[ Feb 3 11:39:10 Executing start method ("/lib/svc/method/nrpe start") ]
ld.so.1: nrpe: fatal: libc.so.1: version `SUNW_1.22.7' not found (required by file /opt/nagios/bin/nrpe)
ld.so.1: nrpe: fatal: libc.so.1: open failed: No such file or directory
Killed
[ Feb 3 11:39:10 Method "start" exited with status 137 ]
Killed
Killed
root@cmnncs01> pvs /usr/lib/libc.so.1
libc.so.1;
SUNW_1.23;
SUNW_1.22.3;
SUNW_1.22.2;
SUNW_1.22.1;
SUNW_1.22;
SUNW_1.21.3;
SUNW_1.21.2;
SUNW_1.21.1;
SUNW_1.21;
SUNW_1.20.4;
SUNW_1.20.1;
SUNW_1.20;
SUNW_1.19;
SUNW_1.18.1;
SUNW_1.18;
SUNW_1.17;
SUNW_1.16;
SUNW_1.15;
SUNW_1.14;
SUNW_1.13;
SUNW_1.12;
SUNW_1.11;
SUNW_1.10;
SUNW_1.9;
SUNW_1.8;
SUNW_1.7;
SUNW_1.6;
SUNW_1.5;
SUNW_1.4;
SUNW_1.3;
SUNW_1.2;
SUNW_1.1;
SUNW_0.9;
SUNW_0.8;
SUNW_0.7;
SISCD_2.3;
SYSVABI_1.3;
SUNWprivate_1.1;
rnpe agent unable to start for solaris 10 SPARC
- Box293
- Too Basu
Re: rnpe agent unable to start for solaris 10 SPARC
Thanks for your help
I am getting the same problem. May I know how this issue resolve?
thanks you,
Mel
thanks you,
Mel
Please do not post in other threads and then create your own for the same issue. We will be closing this thread and will deal with the issue here: https://support.nagios.com/forum/viewtopic.php?t=34973
Did you read the guide that was posted there?
Former Nagios Employee.
me.
me.
