Monitor Serial Ports on Windows
I need to be able to monitor both serial-to-ethernet and serial ports for a project on a Windows 7 machine. Just looking for ideas on the best approach if performance counters might work or a powershell script to capture serial port status. I do not need to parse data on the serial port only determine if it is working or not. Any ideas would be appreciated.
Mike Weber
Nagios Training/Consulting
Re: Monitor Serial Ports on Windows
Mike, do you want to know if there is a serial port available or if it is usable (or in use)?
If you can put together a powershell script to give you the info you need, you could call it with NSClient++ or NCPA. I tested running the following two commands from within the powershell terminal on a Windows 7 box, and the output looked promising. Maybe you can try something similar in your script.
Get-WMIObject Win32_SerialPort
Get-WMIObject Win32_SerialPort | Select-Object Name,DeviceID,DescriptionBe sure to check out our Knowledgebase for helpful articles and solutions!
Thanks for your help, just what I needed. If you leave this open I will post the code when I get it working.
Mike Weber
Ok. We'll leave this open for now.
Here is what I worked out:
# Script to check COM port is used.
# Returns 0 if it is being used;
# Returns 2 if it's not used, or error occured.
# Usage:
# PowerShell.exe -ExecutionPolicy unrestricted -command ".\PS_CheckCOMPorts.ps1"
# PowerShell.exe -ExecutionPolicy unrestricted -command ".\PS_CheckCOMPorts.ps1" "COM1"
# PowerShell.exe -ExecutionPolicy unrestricted -command ".\PS_CheckCOMPorts.ps1" "COM1,COM3"
Param(
[array] $COM_PORTS = @() # Can be set as a command line parameter: COM1, COM2, COM3, COM4. If not set, all available ports will be checked.
$errorsCount = 0 # Used to track errors
if ($COM_PORTS.Count -eq 0) # check all available ports
$COM_PORTS = ([System.IO.Ports.SerialPort]::GetPortNames() | sort)
if ($COM_PORTS -eq $null)
Write-Error "COM ports are not found!"
$errorsCount += 1
else
foreach ($COM_PORT_NAME in $COM_PORTS)
Write-Host "Checking $COM_PORT_NAME..."
# Let's try to open COM port.
Try
$port = new-Object System.IO.Ports.SerialPort($COM_PORT_NAME)
# if it's already used the exception will be thrown
$port.open()
$port.close()
# if we are here - it means port is not used. Exception wasn't thrown
Write-Host -ForegroundColor Red "$COM_PORT_NAME is not used [FAIL]"
$errorsCount += 1 # Port is not used
Catch
$ErrorMessage = $_.Exception.InnerException
if($ErrorMessage -match "Access to the port '$COM_PORT_NAME' is denied.")
# port is used
Write-Host -ForegroundColor Green "$COM_PORT_NAME is used [OK]"
else
Write-Error $ErrorMessage
$errorsCount += 1
if ($errorsCount -gt 0)
exit 2
}Mike Weber
MIke, I tested the script. I shows if the device is in use or not. It doesn't show if the device is connected (but not in use).
Anyway, I placed the script in the NSClient++ scripts directory, created a command in the nsclient.ini, restarted the NSClient++ service and ran on the Nagios XI server:
I connected a device to the serial port and ran the check again - same output. Then I used putty to connect to COM1 and ran the command again. Now I got:
Hope this helps.
[root@testbox libexec]# ./check_nrpe -H x.x.x.x -c check_serial_port
Checking COM1...
COM1 is not used [FAIL]
Checking COM3...
COM3 is not used [FAIL]|Code: Select all
Checking COM1...
COM1 is used [OK]
Checking COM3...
COM3 is not used [FAIL]|Be sure to check out our Knowledgebase for helpful articles and solutions!
