Since a few days, I always have to apply configuration twice. Is this a known issue? Is there a fix / workaround?
The first time I hit apply configuration, it goes straight to the configuration snapshots page. The second time it applies normally.
Grtz
Willem
Always have to apply twice
Nagios XI 5.8.1
https://outsideit.net
Re: Always have to apply twice
It is a known issue, and will be resolved in the next release.WillemDH wrote:Is this a known issue? Is there a fix / workaround?
Unfortunately, we cannot "patch this particular item by itself.
Ok, I'll wait for the patch. You can close the thread. Thanks.
Nagios XI 5.8.1
