Deleting multiples hosts and services
paulol
Post by paulol »
how do I delete at once multiple hosts and services on nagios xi ?
cmerchant
Re: Deleting multiples hosts and services
Post by cmerchant »
You can delete multiple hosts and services (delete the services first).
In XI --> Configure --> CCM --> Monitoring --> Services,
at the bottom of the screen on the right Click on Limit Results To: None
at the top of the Services screen, you can either
1) fill in the Search: entry and click on Search
or
2) use the drop down menu box Filter by Config Name: (and click on the select host to match)
when you have the list to display the items to delete, click on the check box just left of the Config Name Title Line, (this is for mass changes)
and at the bottom of the screen, click on the drop down menu for With Checked , select Delete and hit Go button.
Repeat the same process for Hosts
When you are all done, you can hit Apply Configuration to commit your changes.
paulol
Post by paulol »
Thank you, cmerchant.
