When running through the config wizard, the default setting for notification interval is 60 min.
Is it possible to change that value? if so, where?
Change Wizard default notification time
Everybody is somebody else’s weirdo
- Box293
- Too Basu
Re: Change Wizard default notification time
Not at this point in time, it is currently a feature request however I do not know when it is likely to be implemented.
You can actually edit the wizard code and specify a value that will over-ride the value you populate. Here is a thread that roughly talks about the section of code you need to play around in. In your case you'll be wanting to define notification_interval.
NOTE: wizards can get replaced during an upgrade, so it's best to make backups of your custom wizards.
http://support.nagios.com/forum/viewtopic.php?f=16&t=29445&hilit=+wizard&p=113618#p113221As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
great, I will check it out....
real quick question....a bit off topic.
I just purchased XI yesterday and got my 'real' login name and password.
Is it possible to link this account and the real account?
Yes. Send an email from your registered email address to [email protected] and request it. After that, it should only take a moment.
