Nagios Wmi integration
venkitesh
Post by venkitesh »
Hi All,
i have added one windows server using wmi in nagios xi server and it got added successfully.
But my mistake i have given wrong wmi password. But i have not seen anywhere to edit these settings.
So i have deleted that host and re-added again.
Is there any way we can edit those settings without re-adding the host.
Kindly help
Re: Nagios Wmi integration
This would be in the Core Config Manager under the Configure section. You would want to click "Services" on the left, then search for that particular service, and edit the one for that host. In the Common Settings window you will see a listing of "$ARG1$", "$ARG2$", etc. and your password will be in one of those. Edit that, save the service, then click "Apply Configuration" for the changes to take effect.
venkitesh
Post by venkitesh »
Thanks donald
