I am trying to install NNA for my customer whom has recently purchased the product on my recommendation. I am unable to email Nagios customer support or post in the customer forum as the product is obviously registered against my customers email address. Can an administrator please assist in escalating my support privileges so I can help my customer with the installation?
The issue I am having with the installation is shown below;
[root@xxx001 nagiosna]# ./fullinstall
Your system $PATH does not include /sbin and /usr/sbin. This is usually the result of installing GNOME rather than creating a clean system.
Adding /sbin and /usr/sbin to $PATH.
Nagios Network Analyzer Installation
DATE: Fri Feb 6 16:55:42 AEST 2015
DISTRO INFO:
RedHatEnterpriseServer
6.6
x86_64
Running 'prereqs'...
Enabling epel repo...
INSTALLATION ERROR!
in your communications with Nagios Enterprises technical support.
The step that failed was: 'prereqs'
Thanks.
NNA Installation Error
Re: NNA Installation Error
You will need to contact [email protected] for any account-related information or changes.
As for that error, one of the first things it mentions is having a GUI installed. Is this the case? We recommend and will support a clean, minimal install of RHEL or CentOS 5/6 (with support for 7 coming soon). Including a GUI will mess with the paths and dependencies, so a minimal install is needed.
Thanks for responding. My installation does not include a GUI, it has a minimal installation of RHEL 6.6.
[root@xxxl001 nagiosna]# lsb_release -a
LSB Version: :base-4.0-amd64:base-4.0-noarch:core-4.0-amd64:core-4.0-noarch
Distributor ID: RedHatEnterpriseServer
Description: Red Hat Enterprise Linux Server release 6.6 (Santiago)
Release: 6.6
Codename: Santiago
What's strange is that my environment variable for PATH is correct, however the install script says it is not correct?
[root@xxxl001 nagiosna]# env | grep PATH
PATH=/usr/bin:/bin:/usr/sbin:/sbin
[root@xxxl001 nagiosna]# ./fullinstall
DATE: Tue Feb 10 12:47:43 AEST 2015
DISTRO INFO:
6.6
x86_64
INSTALLATION ERROR!
Release: 6.6
Codename: Santiago
DISTRO INFO:
6.6
x86_64
INSTALLATION ERROR!
Can you post the whole install.log?
FYI, the path on my NNA test box is:
I don't remember modifying it, so this should be the "default"...
PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/root/binBe sure to check out our Knowledgebase for helpful articles and solutions!
Interesting, I have not changed the PATH from the defaults either.
This is on a Redhat Enterprise server 6.6.
I tried adding the path you listed but I got the same result.
Are there any Redhat packages that need to be installed prior to running the install script as I couldn't see any listed in the installation document?
Here is the install.log ...
[root@xxx001 nagiosna]# cat install.log
DATE: Wed Feb 11 13:00:00 AEST 2015
DISTRO INFO:
6.6
x86_64
INSTALLATION ERROR!
DISTRO INFO:
6.6
x86_64
INSTALLATION ERROR!
Does this machine have internet access?
Hi Scott,
Thanks that was the issue. I needed to add proxy info to my environment variable.
Good to hear. I'll be closing this thread now, but feel free to open another if you need anything in the future!
