How to configure service dependencies if assigned to HG
questrad
Post by questrad »
Can you please give me some advise on how to configure dependencies based on following configuration.
So, we have:
2 hostgroup HG_A and HG_B
5 hosts H1, H2, H3, H4, H5
HG_A includes H1, H3, H4
HG_B includes H2, H5
And following 3 services, as defined in NagiosXI CCM:
Service_1:
	Config Name: Serv1
		(this will be file name on server)
	Description: S1
		(this is the actual service name in CCM configuration or service_description)
Service_2:
	Config Name: Serv1
	Description: S2
Service_3:
	Config Name: Serv2
	Description: S1
Each service has own contact groups, times to check and etc.
And those services are applied to hostgroups, not to servers directly.
Service_1, Service_2 to HG_A
Service_2, Service_3 to HG_B
In CCM configuration when I want to start making service dependencies, I am confusing, because I see only the service description and I cannot determinate - which one is for HG_A was assigned and which one was assigned to HG_B
For example:
Service_1 and Service_3 has the same description, but they are for different server types.
Here is screen shots
How the services are showing in Service Dependencies CCM config - I think you need to show here as well the config name.
And the services itself:
Re: How to configure service dependencies if assigned to HG
What is the version of Nagios XI that you are currently using? You will be able to see both the host and the service in a format -> "host - service" under the "Service Dependency Management" window in the latest release of XI. See an example below:
questrad
Post by questrad »
I am using Nagios XI 2014R2.0
The hostnames are not shown as these services are added to hostgroups and not added to any hosts. I would recommend using more descriptive names (not using the same name for all of them).
questrad
Post by questrad »
So, you suggest to use for example:
HG1
HG2
Service
Description: PING
For HG1 naming the description as HG1_Ping and etc.?
What if I have longer host-group naming?
I dont think it is correct.
It is better if the CCM can show the "Config Name" of the service if the service is not assigned to any host directly.
I just spoke to our developers about that. I was told that you should be able to use ANY of the services listed, provided you use the correct name (casing matters - PING is not the same as Ping).
We will be moving away from displaying services under the "Service Dependency Management" in the "host - service" format. Only the service name will be displayed and duplicates will be removed. So for example, if you had 5 services named PING, only 1 PING would be shown.
Hope this helps.
