./check_snmp
sunilkdp
./check_snmp
Post by sunilkdp »
Hi
Please help me on how to monitor cisco switches and routers through SNMP, I am trying to define given below command it is showing error.
./check_snmp -H X.X.X.X -P 2c -c snmp@123! -o sysUpTimeInstance
Error: External command error: Timeout: No Response from X.X.X.X:161.
Thanks and Regards,
Sunil
Mob: 8527230555.
Re: ./check_snmp
I believe instead of "-c" you need to have "-C" in order to pass the community string. The low case "-c" is for the critical threshold...
./check_snmp -H X.X.X.X -P 2c -C snmp@123! -o sysUpTimeInstance
Can you run the snmpwalk against this device?
snmpwalk -v2c X.X.X.X  -c snmp@123!
Is UDP port 161 open?
nmap -sU X.X.X.X -p 161
sunilkdp
Re: ./check_snmp
Post by sunilkdp »
Thank you for your help now it is working fine.
