i used to add a switch using comfiguration wizard, but i have removed all services and hosts already.
However i can still see a lot of rd files under /var/lib/mrtg as below:
172.30.253.102_10.rrd
172.30.253.102_11.rrd
172.30.253.102_12.rrd
172.30.253.102_14.rrd
172.30.253.102_15.rrd
172.30.253.102_16.rrd
172.30.253.102_1.rrd
172.30.253.102_2.rrd
172.30.253.102_3.rrd
172.30.253.102_4.rrd
172.30.253.102_5.rrd
172.30.253.102_6.rrd
172.30.253.102_7.rrd
172.30.253.102_8.rrd
172.30.253.102_9.rrd
and they still automatically updade every minute, even through i have deleted all the services and host from nagios. this is a memery waste
how do i clear all the information about one host using nagios XI?
Lisa
delete rrd files automatically
Re: delete rrd files automatically
Those rrds are populated by mrtg, and I do not believe XI automatically removes the related mrtg config when the associated service is removed. The mrtg configs are located at:
Remove the corresponding configs (or parts of the configs) from the directory above and then remove the related rrds from /var/lib/mrtg.
/etc/mrtg/conf.d/ Former Nagios employee
abrist wrote:Those rrds are populated by mrtg, and I do not believe XI automatically removes the related mrtg config when the associated service is removed. The mrtg configs are located at:Remove the corresponding configs (or parts of the configs) from the directory above and then remove the related rrds from /var/lib/mrtg.Code: Select all
/etc/mrtg/conf.d/
Thanks, if i rename the cfg file of that switch, the rrd fild will not be updated anymore.
you can close the thread.
