Nagios 4.0.8 Web Interface Not Working
I have newly installed nagios 4.0.8 getting error "This webpage is not available"
Re: Nagios 4.0.8 Web Interface Not Working
Is your webserver running?
netstat -tulpn | grep 80Rob Hassing
Now it's working i have turn off iptables service. But it gives "internal server error" when i click on any button like services or host.
maybe you need to restart de httpd service?
And make sure nagios is running.
Rob Hassing
What OS and version are you using?
CentOS 6.6 and Nagios 4.0.8
Even check_nrpe is placed under libexec folder. Kindly check the attachment picture.
(No output on stdout) stderr: execvp(/usr/local/nagios/libexec/check_nrpe, ...) failed. errno is 2: No such file or directory
Any update regarding to this issue ?
Does the file exist?
ls -l /usr/local/nagios/libexec/check_nrpeRob Hassing
yes
-rwxr-xr-x 1 root root 22256 May 1 2014 /usr/local/nagios/libexec/check_nrpe
