Long story short we had some issues getting access past our Firewall, we've now got that issue resolved so attempting to upgrade... seemed to get pretty far then failed here:
*** Main program, CGIs and HTML files installed ***
You can continue with installing Nagios as follows (type 'make'
without any arguments for a list of all possible options):
make install-init
- This installs the init script in /etc/rc.d/init.d
make install-commandmode
- This installs and configures permissions on the
directory for holding the external command file
make install-config
- This installs sample config files in /usr/local/nagios/etc
make[1]: Leaving directory `/tmp/nagiosxi/subcomponents/nagioscore/nagios-4.0.8'
Running configuration check...
Stopping nagios:. done.
Starting nagios: done.
Updating NRDP..
Enabling Nagios repo...
Installing Nagios Repo PKG: packages/nagios-repo-6-2.el6.noarch.rpm
warning: packages/nagios-repo-6-2.el6.noarch.rpm: Header V4 RSA/SHA1 Signature, key ID 1e924cb3: NOKEY
Preparing... ##################################################
nagios-repo ##################################################
no crontab for nagios
Saving old crontab to /tmp/root.crontab.orig...
Removing XI cron jobs...
"-":4: bad minute
errors in crontab file, can't install.
Well, those look fine as well. Do you get the same error if you rerun the upgrade, do you get the error again?
*** Exfoliation theme installed ***
NOTE: Use 'make install-classicui' to revert to classic Nagios theme
make install-basic
make[1]: Entering directory `/tmp/nagiosxi/subcomponents/nagioscore/nagios-4.0.8'
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/libexec
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/var
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/var/archives
/usr/bin/install -c -m 775 -o nagios -g nagcmd -d /usr/local/nagios/var/spool/checkresults
chmod g+s /usr/local/nagios/var/spool/checkresults
make install-init
make install-config
Updating NRDP..
Saving old crontab to /tmp/root.crontab.orig.1...
Note: Even though the output from the commands you ran looked fine, you may have some weird line endings, etc. I would recommend running dos2unix against each crontab file just in case, for example:
