nagios perf graph using default template
how do i add or generate new template for performance graph? right now all my services are using default template.
Re: nagios perf graph using default template
This is a feature of PNP. Although we package and ship PNP as part of our product the best I can do for support is direct you to the PNP documentation.
http://docs.pnp4nagios.org/pnp-0.4/tpl
I'm sure you can do whatever you wanted using extended service configuration as described else where on the forums, for providing limited access for users to acknowledge alters.
