Logstash stopped working - Too many Open files issue
teirekos
Post by teirekos »
Logstash stopped working normally. The following error appears in the logstash log.
{:timestamp=>"2015-02-12T10:04:29.478000+0200", :message=>"Failed to flush outgoing items", :outgoing_count=>1, :exception=>#<SocketError: initialize: java.net.SocketException: Too many open files>, :backtrace=>["org/jruby/ext/socket/RubySocket.java:190:in `initialize'", "org/jruby/RubyIO.java:852:in `new'", "/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/ftw-0.0.39/lib/ftw/connection.rb:146:in `connect'", "org/jruby/RubyArray.java:1613:in `each'", "/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/ftw-0.0.39/lib/ftw/connection.rb:139:in `connect'", "/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/ftw-0.0.39/lib/ftw/agent.rb:406:in `connect'", "org/jruby/RubyProc.java:271:in `call'", "/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/ftw-0.0.39/lib/ftw/pool.rb:48:in `fetch'", "/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/ftw-0.0.39/lib/ftw/agent.rb:403:in `connect'", "/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/ftw-0.0.39/lib/ftw/agent.rb:319:in `execute'", "/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/ftw-0.0.39/lib/ftw/agent.rb:217:in `post!'", "/usr/local/nagioslogserver/logstash/lib/logstash/outputs/elasticsearch/protocol.rb:106:in `bulk_ftw'", "/usr/local/nagioslogserver/logstash/lib/logstash/outputs/elasticsearch/protocol.rb:80:in `bulk'", "/usr/local/nagioslogserver/logstash/lib/logstash/outputs/elasticsearch.rb:315:in `flush'", "/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.17/lib/stud/buffer.rb:219:in `buffer_flush'", "org/jruby/RubyHash.java:1339:in `each'", "/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.17/lib/stud/buffer.rb:216:in `buffer_flush'", "/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.17/lib/stud/buffer.rb:193:in `buffer_flush'", "/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.17/lib/stud/buffer.rb:159:in `buffer_receive'", "/usr/local/nagioslogserver/logstash/lib/logstash/outputs/elasticsearch.rb:311:in `receive'", "/usr/local/nagioslogserver/logstash/lib/logstash/outputs/base.rb:86:in `handle'", "/usr/local/nagioslogserver/logstash/lib/logstash/outputs/base.rb:78:in `worker_setup'"], :level=>:warn}
Re: Logstash stopped working - Too many Open files issue
Follow instruction here for each of your servers:
http://support.nagios.com/forum/viewtop ... 83#p122363
and then restart logstash (on each server)
service logstash restart
Finally, this is a known bug that will be fixed in the next release after final testing (next week at the latest)
teirekos
Post by teirekos »
thanx a lot.
When I restarted the service I got the following:
[root@NagiosLogServer ftw]# service logstash restart
Failed to set capabilities on file `/usr/lib/jvm/java-1.7.0-openjdk-1.7.0.65.x86_64/jre/bin/java' (No such file or directory)
usage: setcap [-q] [-v] (-r|-|<caps>) <filename> [ ... (-r|-|<capsN>) <filenameN> ]
Note <filename> must be a regular (non-symlink) file.
Restarting Logstash Daemon: [ OK ]
[ OK ]
Any ideas?
teirekos
Post by teirekos »
I also have this now:
{:timestamp=>"2015-02-12T16:53:52.370000+0200", :message=>"syslog udp listener died", :address=>"0.0.0.0:5544", :exception=>#<SocketError: bind: name or service not known>, :backtrace=>["org/jruby/ext/socket/RubyUDPSocket.java:160:in `bind'", "/usr/local/nagioslogserver/logstash/lib/logstash/inputs/syslog.rb:116:in `udp_listener'", "/usr/local/nagioslogserver/logstash/lib/logstash/inputs/syslog.rb:76:in `run'"], :level=>:warn}
{:timestamp=>"2015-02-12T16:53:57.371000+0200", :message=>"syslog tcp listener died", :address=>"0.0.0.0:5544", :exception=>#<Errno::EADDRINUSE: Address already in use - bind - Address already in use>, :backtrace=>["org/jruby/ext/socket/RubyTCPServer.java:118:in `initialize'", "org/jruby/RubyIO.java:852:in `new'", "/usr/local/nagioslogserver/logstash/lib/logstash/inputs/syslog.rb:135:in `tcp_listener'", "/usr/local/nagioslogserver/logstash/lib/logstash/inputs/syslog.rb:90:in `run'"], :level=>:warn}
I'm guessing you had followed the Listening on privileged ports doc?
http://assets.nagios.com/downloads/nagi ... Server.pdf
Can you show the following
cat /etc/sysconfig/logstash|grep setcap
If you get a line like this, it is possible that the version of java updated
setcap 'cap_net_bind_service=+ep' /usr/lib/jvm/java-1.7.0-openjdk-1.7.0.65.x86_64/jre/bin/java
Lets delete that line from /etc/sysconfig/logstash, and run the following
echo -e "\nsetcap 'cap_net_bind_service=+ep' \$(readlink -f \$(which java))" >> /etc/sysconfig/logstash
This will continuously update if the java version updates. I'm also going to modify the doc so others will not have the same issue.
After making the changes, you should restart logstash again
teirekos
Post by teirekos »
Yes indeed, I am strugling to sent logs from AIX machines via syslog 514 ...
Yes logstash restart is clear now.
You might also be interesting in the following error:
{:timestamp=>"2015-02-12T17:06:57.279000+0200", :message=>"syslog tcp listener died", :address=>"0.0.0.0:5544", :exception=>#<Errno::EADDRINUSE: Address already in use - bind - Address already in use>, :backtrace=>["org/jruby/ext/socket/RubyTCPServer.java:118:in `initialize'", "org/jruby/RubyIO.java:852:in `new'", "/usr/local/nagioslogserver/logstash/lib/logstash/inputs/syslog.rb:135:in `tcp_listener'", "/usr/local/nagioslogserver/logstash/lib/logstash/inputs/syslog.rb:90:in `run'"], :level=>:warn}
{:timestamp=>"2015-02-12T17:07:02.281000+0200", :message=>"syslog tcp listener died", :address=>"0.0.0.0:5544", :exception=>#<Errno::EADDRINUSE: Address already in use - bind - Address already in use>, :backtrace=>["org/jruby/ext/socket/RubyTCPServer.java:118:in `initialize'", "org/jruby/RubyIO.java:852:in `new'", "/usr/local/nagioslogserver/logstash/lib/logstash/inputs/syslog.rb:135:in `tcp_listener'", "/usr/local/nagioslogserver/logstash/lib/logstash/inputs/syslog.rb:90:in `run'"], :level=>:warn}
teirekos
Post by teirekos »
For some strange reason the Input regarding syslog on port 5544 was duplicated! :-0
I've deleted one of them and now seems ok.
Thanx for your help. Pls close the thread.
