Checking Federation Services with Nagios
litsupport.box
Post by litsupport.box »
Is there a proper way to check if the Federation Services(ADFS) are running properly? with Nagios of course :)
Kind regards,
Farid
Nagios XI Version : 2014R2.6
fqdn 2.6.32-431.17.1.el6.x86_64 x86_64
CentOS release 6.5 (Final)
Gnome is not installed
Proxy appears to be in use
VMware Image
Mod Gearman
Re: Checking Federation Services with Nagios
I didn't find any suitable plugins on the Nagios Exchange. If there are some, I didn't see them. :)
If you had a script that does the job for you, you could call it with NCPA or NSClient++. I found a link to a powershell script aimed at finding ADFS errors - not sure if this is going to help but here it is:
http://www.css-security.com/blog/a-powe ... -0-errors/
litsupport.box
Thank you for your reply, i thought so hm my question is answered #lock.
VMware Image
Mod Gearman
cmerchant
Post by cmerchant »
We'll go ahead and close the thread. Thanks.
