MySQL database
dhananjay
MySQL database
Post by dhananjay »
Can we use single instance of MYSQL database for multiple XI servers? Can we install MYSQL on one machine and the XI server on another? if so how can we configure it?
litsupport.box
Re: MySQL database
Post by litsupport.box »
We do the following in our organisation: http://assets.nagios.com/downloads/nagi ... Server.pdf
Nagios XI Version : 2014R2.6
fqdn 2.6.32-431.17.1.el6.x86_64 x86_64
CentOS release 6.5 (Final)
Gnome is not installed
Proxy appears to be in use
VMware Image
Mod Gearman
Re: MySQL database
@litsupport.box is on track, however it is worth pointing out, if you are using the same server for multiple installs, you will need to name the DBs something different for each, XI install.
i.e. They can share the same MySQL server but not share the same databases.
litsupport.box
Re: MySQL database
scottwilkerson wrote:@litsupport.box is on track, however it is worth pointing out, if you are using the same server for multiple installs, you will need to name the DBs something different for each, XI install.
Good thing to know, haven't had to do anything like that since im only using one still good to know thx.
VMware Image
Mod Gearman
Re: MySQL database
@dhananjay - Let us know if this answered your original query.
