I am trying to configure the windows server through windows snmp monitoring wizard option in Ngaios XI, There is some few option mentioned so please can someone help me what is the utilization of SNMP Authentication, how I can configure it. (Screen shot attached)
Kindly suggest....
Sjain
Windows snmp monitoring wizard option
shailu2014
Re: Windows snmp monitoring wizard option
Those Authentication settings are if you installed and setup SNMP version 3 on your windows server that you want to monitor.
If you did not setup SNMP version 3, you can ignore those settings.
Here is a quick link for installing SNMP on Windows 2008
http://blog.skufel.net/2012/09/how-to-a ... r-2008-r2/
