How can I disbale the Nagios XI update check?
xlin125
Post by xlin125 »
We are getting the Notices of Update Check Failed when we login to Nagios XI. It seems this check is performed automatically when the Nagios administrator logs in. We like to disable this check and notification. If needed, we can do a manual check and then decide whether we want to do the update. How can we disable the update check? Thanks.
Re: How can I disbale the Nagios XI update check?
Admin -> Manage System Config -> uncheck "Automatically Check for Updates" box -> Update Settings
