hello,we try to install the agent linux-nrpe-agent and we make full install but appears this error, some one can help us.
Protected multilib versions: openssl-1.0.1e-15.el6.i686 != openssl-1.0.1e-16.el6_5.4.x86_64
You could try using --skip-broken to work around the problem
monitoreo1
Re: Protected multilib versions: openssl-1.0.1e-15.el6.i686
Did thid get in the wrong forum, or are you trying to install the agent on your Nagios Log Server?
also, the 2 packages you are showing are different architechures, are you on a 32 or 64bit system?
uname -a-
monitoreo1
Thanks Scott, we was doing something wrong, fortunately we have fixed the issue..scottwilkerson wrote:Did thid get in the wrong forum, or are you trying to install the agent on your Nagios Log Server?
also, the 2 packages you are showing are different architechures, are you on a 32 or 64bit system?Code: Select all
uname -a
This issue has been locked and marked as resolved. Thanks!
