check_win_net_usage always zero
sonuma
Post by sonuma »
I read this topic,
http://support.nagios.com/forum/viewtop ... 5&start=10
I have the same problem, but for me I cannot resolve the problem.. when I launch the command, the result is always 0Bytes sent or receive....
[root@nagios libexec]# ./check_win_net_usage.sh -H bck -s **** -p 12489 -i "Broadcom BCM5709C NetXtreme II GigE [NDIS VBD Client]"
Network OK - 0 Bytes received/sec, 0 Bytes sent/sec|bytes_in=0;bytes_out=0
Re: check_win_net_usage always zero
Have you tried running the plugin against a different interface? Does it work if you do so? I tried the plugin and it worked fine for me:
[root@testbox libexec]# ./check_win_net_usage.sh -H x.x.x.x -p 12489 -s password -i "Intel[R] 82579LM Gigabit Network Connection"
Network OK - 5874 Bytes received/sec, 849084 Bytes sent/sec|bytes_in=5874;bytes_out=849084
Is there any traffic on the "Broadcom BCM5709C NetXtreme II GigE [NDIS VBD Client]" interface? Can you show us a graph in the Performance Monitor?
Post by Box293 »
sonuma wrote:Broadcom BCM5709C NetXtreme II GigE [NDIS VBD Client]
Is this NIC a member of a team? If it is, you should be using the name of the team instead.
In Performance Monitor, when you add that counter is it reporting any values?
sonuma
Post by sonuma »
The NIC is not a member of teaming.
Please find screenshot
sonuma
Post by sonuma »
perf graph
sonuma
Post by sonuma »
If I try on another server, with another NIC, i have the same result... strange !
sonuma
Post by sonuma »
I found my problem, It's a FRENCH windows system :), not US.
So if I launch the correct check_nt with french parameter, i receive a result
Now, I have to find the correct definition of check_nt command because there is a problem with special character (é, ç...) :)
jolson
Attack Rabbit
Post by jolson »
sonuma wrote:I found my problem, It's a FRENCH windows system :), not US.
Sounds good! I will lock this post out, and if you have any additional problems please feel free to create another one. Thanks!
Twits Blog
