I need to put the HostAlias in the Notifications Reports, like:
Platform = HostAlias...
Can help me ?
Regards!
Sergio
Custom Report Notifications
Re: Custom Report Notifications
This is possible, but not super easy to accomplish as the notification query only uses the relational table with object names, not the actual host/service configuration/history table as that information is pulled from the notifications table which does not include the object alias.
This would have to be a feature request, you are welcome to open on the tracker at: http://tracker.nagios.com
