notify if port is up instead of down
rickb
Post by rickb »
New to Nagios and I am setting up switch monitoring. I ran through the switch wizard and got most of what I needed setup but I need to trigger an alert if the port is up instead of down. Is there a way to do this? I have Googled but not seeing anything.
Nagios XI 2014R2.0 (VMware image)
Thanks!
jdalrymple
Skynet Drone
Re: notify if port is up instead of down
Post by jdalrymple »
rickb,
How are you monitoring if the port is down? Off the cuff I suggest that using the negate plugin can invert your results if you have a configuration in place to notify if the switch ports are down:
http://exchange.nagios.org/directory/Do ... in/details
Does that help?
rickb
Post by rickb »
Awesome! Work perfectly. :D
I'll be closing this thread now, but feel free to open another if you need anything in the future!
