httpd status unknown due to insufficient privileges.
sureshkraj2012
Post by sureshkraj2012 »
/usr/local/nagios/libexec/check_init_service httpd
It works when I execute with sudo.
sudo /usr/local/nagios/libexec/check_etc_service httpd
httpd (pid 1995) is running...
So I have declared following command in nrpe.cfg. But it gives error "unable to read nrpe output"
command[check_httpd]= sudo /usr/local/nagios/libexec/check_init_service httpd
Not sure what I missing here. Could you help me?
Re: httpd status unknown due to insufficient privileges.
Does the nagios user on the remote system have sudo privileges for
/usr/local/nagios/libexec/check_init_service *
