I have some bug on apace logging.
Apache Dashboard:
Oops! FacetPhaseExecutionException[Facet [0]: (value) field [bytes] not found]
Apace logging
Apace logging
Re: Apace logging
Have you received any apache logs with type apache_access? Can you do a quick search at the top for
and show a record
type:apache_accessThanks
Re: Apace logging
nothing
Regards. Einar
Regards. Einar
Re: Apace logging
Product Update Check
Up To Date
Your installation of Nagios Log Server (2015R1.3) is up-to-date, so no upgrade is required. The latest version of Nagios Log Server is 2015R1.3, which was released on 2015-02-12.
Up To Date
Re: Apace logging
Since there isn't any Apache information on the logserver for the bandwidth calculation, it is giving you this message.
Re: Apace logging
Hi
Sorry my mistake
I use a custom log name on that linux apache server
Now I get logging
same error
Sorry my mistake
Now I get logging
same error
