According to nagiosxi license scheme, 1 production, 1 production backup and 1 for development server are required to buy 1 license.
I would like to know how to set up the production and production backup servers.
Nagios XI Active and Backup server
jdalrymple
- Skynet Drone
Re: Nagios XI Active and Backup server
michaelli,
did you review this section of the NagiosXI FAQ?
http://support.nagios.com/wiki/index.ph ... #Licensing
I'm not sure if that's what you're looking for.
From a technical standpoint there is nothing special about the backup and development servers other than the intended purpose. Of course they should all be on separate servers, and depending on your environment you may want your backup server at a separate site. Otherwise the installs are all similar. Does that help?
