hi Support,
I deployed Nagios by importing the appliance on vCenter 5.5. using "nagiosxi-2014r2.5-64.ova" on a Red Hat 64 bit platform.
I am trying to upload the Connection Broker MIB2 from Leostream on the Nagios > Admin > Manage MIBS page so I can test for a customer. When I select 'process trap' option, I receive this error
Uploaded file had one or more failed translations when converting to snmptt mib.
If I do not select 'process trap', the MIB file loads without errors. I reviewed the MIB file but I don't see any syntax problems. Can you let me know how I can upload this MIB with the 'process trap' option? I attached the MIB file that is causing the problem.
thanks!
Louise
MIB2 has snmptt conversion error
jdalrymple
- Skynet Drone
Re: MIB2 has snmptt conversion error
Hi odyssey,
So I have been trying to find a "Leostream Connection Broker MIB" but Google isn't much help. Is that something you could provide us to troubleshoot?
hi Support,
I thought I attached the MIB file, but it must not have made it to your server. I tried again, and also posted it on this link
https://s3.amazonaws.com/leostream-supp ... reamV2.mib
thanks,
Louise
thanks,
Louise
Have you gone through this document to implement SNMP traps in Nagios XI?
http://assets.nagios.com/downloads/nagi ... ios_XI.pdf
jdalrymple
- Skynet Drone
odyssey,
Can you try the attached MIB and see if it solves your problem?
