Monitoring Process on Nagios XI
monitoreo1
Post by monitoreo1 »
Hi Everyone !!!
We need monitor a process with the next logical:
If the execution process return a string, the process status is ok.
If the execution process return a string void, the process status is failed.
How can i implement this logical in Nagios XI?
We are using:
Nagios XI Version : 2014R2.6
x86_64
Red Hat Enterprise Linux Server release 7.0 (Maipo)
Gnome is not installed
Re: Monitoring Process on Nagios XI
Post by Box293 »
It sounds like you want to write your own plugin, or a wrapper script that runs an existing plugin.
Do you have any plugins that sort of do what you want? What have you tried?
