Nagios core is Running in centos
dreamboy_sivak
Post by dreamboy_sivak »
Hi
Getting a below error when send a email using sendmail
OS : centos 6.5
nagios : nagios 4.0
dsn=5.6.0, stat=Data format error . it is getting only when email has been sent to yahoo id. i can able to send other email accounts.
jdalrymple
Skynet Drone
Re: Nagios core is Running in centos
Post by jdalrymple »
What E-mail accounts are you trying to send to that are failing? This error would generally indicate that the MTA is having issues relaying to the address you specified - often a name resolution problem. Can your Nagios server properly query the MX record for the domain you're trying to reach?
