Monitoring web service login
jpipitone
Post by jpipitone »
We want to monitor a login page on our web sites - I take it the best way to do this is by using the Web Transaction monitoring wizard.
We have login pages that reach out to a 3rd party, which calls a web service. The method name is "GetActivityInfoService"
The URL is similar to:
http://secure.thirdparty.com/activityinfo/services/GetActivityInfo?wsdl
Using the Web Transaction monitoring wizard, how would the test case look? I do not know if the method "GetActivityInfoService" is supported by Nagios.
cmerchant
Re: Monitoring web service login
Post by cmerchant »
You might want to check out this document:
http://assets.nagios.com/downloads/nagi ... ios-XI.pdf
jpipitone
Post by jpipitone »
I saw this document. I've read that if we do not specify a method, it defaults to get. As I specified earlier, the method name used for this login form is "GetActivityInfoService"
I am awaiting further details from our web development team on what the postbody would look like. Thanks
jolson
Attack Rabbit
Post by jolson »
I highly suggest reading up on webinject if you'd like to walk through a service. The following page in particular you might find useful:
http://www.webinject.org/manual.html#tcparammethod
Twits Blog
jpipitone
Post by jpipitone »
Thank you
cmerchant
Post by cmerchant »
Just a heads up on the webinject code, the original plugin was written Corey Goldberg and has not been updated since 1.4.1. It is currently maintained by Sven Nierlein on github (current version is 1.8.6):
https://github.com/sni/Webinject
