I want to develop a plugin which detects changes in (some) of a command's output.
For this of course the plugin needs to remember the previous (one or more) results.
Is there a convention where a plugin should store such info?
local storage for plugins
- Box293
- Too Basu
Re: local storage for plugins
A lot of plugins use files in /tmp/
However for those operating systems that dump /tmp/ on a reboot, /var/tmp/ is a better location.
It all depends on how easy or complicated you want to make things.
Ok. I had played with the thought of using /var/spool or such...
/var/tmp is really for temp files, which are not intended to survive across
calls to the same program, so I consider that less of an option...
jdalrymple
- Skynet Drone
Certainly a matter of not only your preference but the reason for the output. If it is simply to measure a rate of change then /tmp should be fine as it will only take 1 iteration of the check to rebase the local storage location. In situations where you're watching for changes that should never occur though you are right, a custom location under var would be more appropriate. There are no documented best practices, feel free to choose the location that suits you and your application best.
