The following path does not exist.
[root@NagiosLogServer2 elasticsearch]# grep http /usr/local/nagioslogserver/etc/conf.d/*
grep: /usr/local/nagioslogserver/etc/conf.d/*: No such file or directory
If you mean the path below no http entry there
[root@NagiosLogServer2 elasticsearch]# grep http /usr/local/nagioslogserver/logstash/etc/conf.d
I also attach you a screenshot from Instance status where mem used is 92%
[root@NagiosLogServer2 yum.repos.d]# tail /var/log/logstash/logstash.log
log4j, [2015-03-03T14:01:05.561] WARN: org.elasticsearch.client.transport: [845bc07c-ed91-4920-8e23-747c9cc699f5] node [#transport#-1][inet[localhost/127.0.0.1:9300]] not part of the cluster Cluster [688cc8f8-067d-46d7-8e7d-0856a5267c32], ignoring...
log4j, [2015-03-03T14:01:10.563] WARN: org.elasticsearch.client.transport: [845bc07c-ed91-4920-8e23-747c9cc699f5] node [#transport#-1][inet[localhost/127.0.0.1:9300]] not part of the cluster Cluster [688cc8f8-067d-46d7-8e7d-0856a5267c32], ignoring...
log4j, [2015-03-03T14:01:15.565] WARN: org.elasticsearch.client.transport: [845bc07c-ed91-4920-8e23-747c9cc699f5] node [#transport#-1][inet[localhost/127.0.0.1:9300]] not part of the cluster Cluster [688cc8f8-067d-46d7-8e7d-0856a5267c32], ignoring...
log4j, [2015-03-03T14:01:20.566] WARN: org.elasticsearch.client.transport: [845bc07c-ed91-4920-8e23-747c9cc699f5] node [#transport#-1][inet[localhost/127.0.0.1:9300]] not part of the cluster Cluster [688cc8f8-067d-46d7-8e7d-0856a5267c32], ignoring...
log4j, [2015-03-03T14:01:25.568] WARN: org.elasticsearch.client.transport: [845bc07c-ed91-4920-8e23-747c9cc699f5] node [#transport#-1][inet[localhost/127.0.0.1:9300]] not part of the cluster Cluster [688cc8f8-067d-46d7-8e7d-0856a5267c32], ignoring...
log4j, [2015-03-03T14:01:30.569] WARN: org.elasticsearch.client.transport: [845bc07c-ed91-4920-8e23-747c9cc699f5] node [#transport#-1][inet[localhost/127.0.0.1:9300]] not part of the cluster Cluster [688cc8f8-067d-46d7-8e7d-0856a5267c32], ignoring...
log4j, [2015-03-03T14:01:35.571] WARN: org.elasticsearch.client.transport: [845bc07c-ed91-4920-8e23-747c9cc699f5] node [#transport#-1][inet[localhost/127.0.0.1:9300]] not part of the cluster Cluster [688cc8f8-067d-46d7-8e7d-0856a5267c32], ignoring...
log4j, [2015-03-03T14:01:40.573] WARN: org.elasticsearch.client.transport: [845bc07c-ed91-4920-8e23-747c9cc699f5] node [#transport#-1][inet[localhost/127.0.0.1:9300]] not part of the cluster Cluster [688cc8f8-067d-46d7-8e7d-0856a5267c32], ignoring...
log4j, [2015-03-03T14:01:45.574] WARN: org.elasticsearch.client.transport: [845bc07c-ed91-4920-8e23-747c9cc699f5] node [#transport#-1][inet[localhost/127.0.0.1:9300]] not part of the cluster Cluster [688cc8f8-067d-46d7-8e7d-0856a5267c32], ignoring...
log4j, [2015-03-03T14:01:50.576] WARN: org.elasticsearch.client.transport: [845bc07c-ed91-4920-8e23-747c9cc699f5] node [#transport#-1][inet[localhost/127.0.0.1:9300]] not part of the cluster Cluster [688cc8f8-067d-46d7-8e7d-0856a5267c32], ignoring...
That last error message looks a little suspect. Just to be sure there's not an obvious error, can you please run the following commands on both of your nodes and return the output:
TwitsBlog Show me a man who lives alone and has a perpetually clean kitchen, and 8 times out of 9 I'll show you a man with detestable spiritual qualities.
